Hello,
I would like to get an opinion regarding the installation of a decorative chrome waterfall to an overflow pool. The waterfall has a separate pump. The contractor implemented in a way that draws water from the balance tank (basically a separate mini pool to store displaced water) with a single pipe and then splits to main circulation pump and waterfall pump. We have a disagreement with the contractor at the moment as currently two pumps affect each other when waterfall is turned on and off and also the water in the balance tank is dirtier in the sense than balance tank accumulates debris (dirt, hair, leaves) in time. I told him to draw water for the waterfall from the main drain at the bottom of the deep end instead. Is this a good practice? Another alternative is to put the waterfall pump in series with the main pump after the sand filter, but I don't know how practical this is.
Thanks
Thanks
