- Aug 23, 2022
- 146
- Plaster
- Pentair Intellichlor IC-60
Hi, we've been trying to get our new pool plastered (Pebble Fina) for the last couple weeks, but excess water weeping through the shell has prevented us from doing so, I'm wondering if this is normal and if there's anything we can do to speed up the process here?
For additional context, a couple of weeks ago the plaster crew came out (~10 guys) and got all setup on the job, started cleaning and prepping for the plaster, however they were unable to get a few places in the shell to stop weeping (using a torch and hot-pack cement) enough to feel confident enough to apply the plaster, so they pulled off the job and said we have to wait for things to dry out more. The pool builder was here every day for the last little bit applying some sealant to the areas, checking progress, etc. This morning the plaster crew showed up again, they again started prepping the shell and working on the weeping areas (torch, hot-pack, etc) before finally pulling off the job again after 1.5 hours. They told me that they just did a job that looked just like this a couple weeks ago, and on Monday they're going to chip it all out and redo it because they didn't wait, so they don't want that to happen to me.
After they pulled off I started speaking with the pool builder who said (very honestly) that he's never had this happen before and that he's been calling other people in the industry that he knows to try and get some pointers due to the historic amount of moisture that we received this winter. He said that one person recommended drilling some 1/4" holes through the shell in a few strategic locations to allow the water to dry out more quickly rather than waiting for it to weep through slowly as it's doing now.
My questions are:
My questions are:
- For as much moisture as we've received, it's nothing compared to many areas of the country where they still build pools successfully, how do they build pools in those areas without this being a problem? I have read many places are worried that their shell will float out of the ground if they drain the water from the pool, so when those pools were built they must have had far more water weeping through their shell than I do.
- Is there any feedback on this plan the pool builder has to drill a few holes in the shell to let the water have a clearer path out? In my mind it makes sense, but I'm also not an expert at all so maybe it's a bad idea for some reason?
- Are there any additional pointers or thoughts on this situation? Perhaps I just need to exercise a greater degree of patience, but it hurts being so close to the finish line and continually delayed. We broke ground on this project in August, and have been perpetually delayed by the weather ever since.
