Is a pH of 6.8 the lowest possible reading in your pH test? If so, then your pH could well be below 6.8. Do you have a "base demand" test in your test kit? If so, then that can be used to figure out how much more pH Up or equivalent you will need. If you don't have a base demand test, then you could add more pH Up, but it will increase your Total Alkalinity (TA). The 7 kgs in 78,000 gallons would raise the TA by 85 ppm so the cloudiness could be from the TA getting higher. It will probably dissipate and clear up since your pH is still low.
I would stop adding the pH Up for now. Are you certain that your pH test is valid -- is it a drop-based test or is it a test strip? You may be better off at this point just aerating your pool water to get the pH higher. Unfortunately, that requires uncovering the pool and it sounds like you need to keep it covered to keep embers and dust out of the pool. If there is a time of day or night when you can have it uncovered and not get too messy, then that will help. While it is uncovered, have the pump running and turn up your returns, assuming your returns have eyeballs where you can redirect the flow more upwards to create waves.
By the way, for the chlorine reading we call it Free Chlorine (FC) and not "CH" since that stands for Calcium Hardness (CH).
How did your pH get so low? Were you using Dichlor and Trichlor regularly and not testing for the pH?
Richard
Richard
