Water Test Kit Advice?
How much of pool school have you read?
For an swg pool we recommend a cya level of 70 to 80 PPM. I would recommend you target on the lower end around 70 PPM initially. Poolmath will calculate how much you need to add to to reach your target from your current level. I tend to split it into two large athletic socks and tie them together and hang them over a pole dangling in front of a return jet.
I still can not believe how clear the pool is. I thought it would never be this clear! Thanks everyone for the help.
And your FC is dangerously low.
Follow the [FC/CYA][/FC/CYA]. Best to never go below Target level FC.
Are you running the SWCG 24 hours a day at 100%? That might come close to keeping up. You might have to add chlorine every couple days.
You should be testing FC and pH every day until you are sure you understand the trends. Then at least 2 or 3X per week.
FC: is 9 CC: is 0.5. I did add 2 gallons of LC yesterday since I was at 2.5 FC the day before. I thought this was sand in the pool and could not figure how it got there. It brooms away. I just cleaned it Friday and now its back again. After reading on here it looks like its algae. How do I get rid of it? You can see black spots In the photo.
7ecc774eb8e50895a853cbaef481a169.heic
aa3c70e72f9c97498decbf22fc717f1c.heic
