Here is a little background about my pool testing procedures. I test my water once a week. usually on Saturdays as I almost always need to add acid. On a monthly basis I break out my Taylor kit, but for quick checks mos weekends, I just use the Aquacheck 7 strips. This weekend cleaning the pool, I noticed the mottling of my dark plaster was worse than normal. I have posted here before about it, and will follow up with questions in that thread. What I found seems to be a large discrepancy between the Taylor kit and the strips when it comes to (CH). I will post my total results below and an image of the strip.
Taylor
FC 3.5
PH 7.7
CYA 50ish
CH 230ish (it takes me between 45 and 50 drops to get it from pink to purple to finally blue again.
Aquacheck - most values above matched except CH. please see attached image. to me it seems to be over 500 in the image. I find it kinda hard to believe with the 18" of rain in 7 weeks, and the amount of draining i have been having to do. had to add 40lbs of salt this weekend too.
Taylor
FC 3.5
PH 7.7
CYA 50ish
