Opened my pool late this year due to cold spring. Quite green on opening. 10 days of slamming cleaned it up. I've had completely clear water for the last month. However, until the recent heat wave the water has been at, or below 24C (I don't heat it) & I kept the solar blanket on except when swimming in order to elevate the water temperature. I only had to add a relatively small amount of chlorine every night to keep the levels above 5 or 6 ppm.
In the last week of 30C + weather the water temperature has risen steadily to 28/29C. I haven't been putting the solar blanket on the pool as I don't mind the water cooling a bit at night & i don't want the water to heat up anymore. For a couple of days the FC levels seem to have dipped below 1 ppm by the end of the day. I had to start adding a lot more chlorine at night. Yesterday, I noticed a little bit of algae on the sides of the pool. I don't know if this means I have to SLAM?
What is the relationship between water temp/sun exposure & chlorine use? Will keeping the solar blanket on during the day reduce chlorine use?
