I am having issues with the water feature draining into the pool. I had searched similar threads to no avail. The water feature which resembles a spa but with no heat and has a spill over, is draining after pool pump to the feature is off. The are two pumps. One for the pool and one for the water feature. There is a return for the water feature on the pool side so water circulates when pool pump cleans at night I believe. I verified that in the pool suction side, the water feature suction is turned off. The Hayward seal (similiar to Jandy) closing the suction from the feature, also was changed. The two check valves were also replaced. I had tried almost every possible valve combination. Suction off at the pool pump and the returns for water feature on, returns slightly on, returns completely closed. I filled the water feature “bowl” and turned the pump off. I closed all returns and still water goes down after about an hour. I can’t hear no gurgling water sounds at all. All o-rings on “Jandy like” valves had been changed. What am I missing? Could there be an underground leak? Here are some pics
