During the SLAM you want it around 30ppm, because that is about as low as you can measure and give reasonable protection of the chlorine from the sun.
After that, depending on your level of sun, you may want a higher CYA for better protection. Even though at a higher CYA you need to maintain a higher FC, you would actually be losing few ppm each day and thus adding less bleach every day.
