I am hoping that what I am describing here is going to make sense. I have a timer on my pump. While the pump is running the water level in the filter basket area is fine. It is totally full and there are no issues. The problem comes when the pump turns back on. There is definitely not as much water in the filter basket area and it takes several minutes for the water level to come up to where it should be. Sometimes it doesn't always come back to where it was. My equipment is located at a little bit of a higher elevation then the pool and there is a flow valve installed to help with water falling back into the pool when the pump is off.
Why is this happening? How can I fix it? I have already had to replace the motor on the pump and the pool is only 5 years old. I am afraid if it continues like this I am going to continue to burn out pump motors. Any input is much appreciated.
Thank you!
Thank you!
