Hi folks,
When I opened my pool in May, I had no issues (that I could tell). It rained nearly everyday that month, and I remember scratching my head thinking that the pool level never met the built-in overflow runoff pipe. Oh well. After a few weeks now (and the backyard remaining swamp-ish even after the sun came out) - I can tell I have a leak somewhere. I knew I had issues in one corner where my vinyl liner has stretched and torn. I patched the heck out of that corner (using many smaller overlapping patches as that seemed to work better; used H66 vinyl cement), but the leak persisted. I was adding water each day to compensate. FYI, I am able to measure the volume of the leak by catching the output from an underground pressure relief drain pipe (the "spring" feeding my backyard swamp). Initially the leak rate was ~ 3oz every 30 seconds.
My latest step was to plug my skimmer pipe, and rule out (or rule in) a leak somewhere in that pipe. I plugged the hole at the skimmer, and set my valve to suck only from the main drains - so I can maintain circulation, but the skimmer pipe is out of the circuit. After ~ 2 days of this setup, the leak rate reduced to 1.5 oz/30 seconds. Aha. After 4 days, the leak is still there, but now even much smaller. Meanwhile, the pool level is down about an inch from nominal due to evaporation.
So, it seems like I have a leak in my skimmer pipe somewhere - would this forum agree?
I think there is also a possibility that I still have a leak in my vinyl somewhere between nominal water level and an inch below that.
My next step was going to be to fill the pool back up to nominal level, and see if my leak rate changes. If so, then I know I still have a problem with the vinyl somewhere.
If I have no leak once the water level is restored, I think I have solid evidence that the leak is in my skimmer pipe somewhere. If it is in the skimmer pipe, then I'm also looking for advice on fixing that. I have seen "Fix-a-Leak" on amazon. Fix-A-Leak says it "Permanently seals leaks and holes up to 1/8 inch in diameter in most any material including plumbing"
Has anyone used this? Pros/Cons? Other ideas?
Thanks for your collective expertise and advice!
