- Sep 17, 2022
- 116
- Vinyl
- Pentair Intellichlor IC-40
recently opened the pool. got to thinking about things I'd like to improve, and what is really worth the effort or not.
1. found that the ring on the outside of one of my eyeball returns is cracked. in researching replacement pieces, I discovered that there are different, eyehole sizes. I havent measured mine yet, but I was thinking of getting a smaller eye hole size to increase the movement of the water. advantage? disadvantage?
2. I am experimenting with dropping my pump RPM. essentially the SWG stops working below 1500, so I have set it to about 1700 rmp. OK? I figure I may need to turn the SWG percentage up a little because of the decrease in flow? just to keep everything where it needs to be.
3. I noticed that one of the two skimmer baskets seems to have weaker suction or movement than the other. My pipes are currently set to have both skimmer baskets and the main drain to full open. I recently read in an old thread that you dont really need to have the main drain fully open? likely because of the pressure at the bottom of the pool. what is the ideal setting for a main and two skimmers? I am thinking of closing the main drain a bit, increasing the pull from the skimmers. thoughts?
