Question in regards to water features..
I'm almost complete with my pool build (Aquasports 52 15x30 Nor Cal Build)
I plumbed for future water features but have a question about the water sitting in the lines.
I plumbed a 3 way valve off my filter (return/feature) and ran a 2" pipe to where my future features will be. I tested the line and valve to make sure I had no leaks. But I realize that I will just have water sitting in that line until I turn it on again. That could be days or months, i'm assuming stagnant water sitting there isn't good.
Did I plumb this wrong? how are others doing this? I searched and searched before plumbing and found the Jandy references showing how to plumb the pad with the correct valves, therefore creating a single spare leg off the return.
Here is my design:
You can see off filter is 3 way, to left is return, to right is feature which has an additional jandy to control flow rate, but this is just a single 2" line to nowhere.. when i'm not using this feature.. water will just sit in that line stagnant?
(the rise on the right was for convenience so the flow valve was not on the ground, and I intended to plumb two separate lines 1 for slide, 1 for water fall but decided to just run 1 2" over for now, that's why the T with a cap is there)
[/URL][/IMG]
Here is my design:
