First time pool owner. Just moved in. Due to high CH and CYA a water exchange is needed (planning on doing it in the next couple days). I've read everything available and want some reassurance I'm heading in the right direction. Currently there's an inline chlorinator which seems to be keeping things clear for now. I've just been running the pump and pressure cleaner. Figured I'd wait until I do the exchange, remove the chlorinator, then begin the TFP method.
I tested everything 3 times. Same results all 3 tests. With CH and CYA I did regular and diluted tests.
FC=8.8
CC=0
PH=7.6
TA=90
CH=1000
CYA=110
Pool Water Temp = 58
Fill Water CH= 125
Fill Water TA = 120
Fill Water Temp =54
DeltaT = -10 (Math may be off, I have no idea)
Based on the DeltaT I should be extracting from the bottom of the pool at the deepest end and filling from a shallow step on the opposing end, correct?
Pool math suggests 63% replacement. Should I round up to 70%?
I'm going to try and get a utility pump that is as close to the flow rate of the fill source as I can. Assuming adjustments will need to be made, how do I adjust the flow rate of a submersible utility pump? I feel like it's going to be difficult to match up flow rates. Am I overthinking this?
Lastly, because I'll be dechlorinating then exchanging water will the first step upon completing water exchange be Slamming the pool? The pool is crystal clear now. Should I expect things to change dramatically during the dechlorinating and exchange process, even if it only takes a day or two?
FC=8.8
CC=0
PH=7.6
TA=90
CH=1000
CYA=110
Fill Water CH= 125
Fill Water TA = 120
Fill Water Temp =54
