Not having much with getting anyone out to look at our issue so I’m holding out hope someone here has had a similar experience. The top stone was dislodged two weeks and pulled away from the mortar joint. In between it happening and getting put back we had some really heavy rain. We aren’t losing any water from the pool or the spa BUT there now seems to be a constant drip from directly below the piece that disconnected. It’s been a week now that it’s been dripping. It doesn’t increase or decrease when the pump is on or off. If I suction with a shop vac I can pull a bit of water, weirdly more over the last few days than when it started. Is it absolutely crazy to think there has been water accumulating through the very small mortar cracks and crevices over the last two years and it’s finally found it’s way out through this pin hole?? Is filling and sealing the hole a bad idea? Will not releasing the water in there cause bigger issues over time? Any words of wisdom would be greatly appreciated!
