Water balancing
doc8404
0
474
Rome, NY
I know this is a personal preference.
Would you bother dropping TA?
current use has pH bounce 7.4 to 8.
FC 2.0 (adding half gallon of 12.5% when done swimming)
CC 0.0
TA 180
pH 7.6
CYA 40
AGP radiant 30’
21,200 gallons
South side of house
Centra NY
Thanks. Reading here I was under the impression I need to drop pH to 7.0-7.2 then aerate or I would be chasing pH.
Last year I never added MA.
this year I’ve been through two gallons already.
Slow and steady works too, areate if your bored. Either way your pool wlll eventually find a balance between TA and PH where the PH is either stable or at least rises slower. Mine likes 7.2 to 7.4. PH. Some run higher 7.6 or 7.8 or so.
Reactions: doc8404
