- Aug 19, 2022
- 77
- Plaster
- CircuPool RJ-60 Plus
I've been wondering about the insulation and warming properties of my pool cover. The combination of the solid safety cover and the underlying air-gap clearly provides significant insulation in the winter: on occasional checks, my water seems to have maintained a temp of around 40-44F despite our cold winter in Southeast Pennsylvania, well above the average air temperatures. I have only a rough understanding of the thermal physics of how this is happening (direct insulation versus protection from radiative loss to space, for example). But I suspect that a big part may be the blanket of warm air that stays trapped below the cover -- which itself is heated by sunlight on the dark plastic. But however it works, there is always a balmy jungle-like atmosphere of steam beneath whenever I peek below the cover.
As Spring starts to near, the lengthening and decreasing obliquity of daylight will naturally increase this effect: the air below the cover will get ever hotter, and that (along with rising soil temperatures) will start to pre-warm my pool. But at some point, such heating must be slower than having a springtime sun shine directly on an open pool. That is, at some point, the pool cover would impede the warming of my pool.
So I am curious: how might we estimate when this switch occurs? That is, when does the warming profile of an open pool exceed that of a closed/covered pool? Or simply, "if I want my pool to warm up as fast as possible for the season, when should I open it?". Maybe the answer is as simple as -- when the average air temperature exceeds that of the water. But I bet that there are many on these forums who have a deeper understanding of these mysteries -- please share your wisdom!
I've usually opened at the end of March. I don't have an active pool heater. But since last year, I've been using a solar cover to speed up the warming (or rather, to slow its cooling at night). Since my pool is surrounded by a significant number of trees, it's a bit of a race against time until the leaves fill out by the end of April. So when should I start that race?
"CYA later" -- and welcome back to all to another pool season!
Sampo
Sampo
