- Jun 1, 2018
- 16,003
- Vinyl
- Hayward Aqua Rite (T-15)
You need to resume the
SLAM Process & make sure you’re passing all 3 end of slam criteria before ending.
You are done when:
CC is 0.5 or lower;
You pass an Overnight Chlorine Loss Test
AND
The water is clear.
(Crystal Clear w/no algae dead or alive)
You should be able to pass all those criteria before closing anyway- this, along with all the other steps in the closing article, ensures a smooth opening in the spring assuming you close after the water is in the low 60’s & falling
and you open before it rises much above 60 degrees in the spring.
www.google.com
www.troublefreepool.com
You are done when:
AND
Closing an In Ground Pool
Winterizing a pool is essential for keeping your in-ground pool protected during cold-weather months. This Pool Repair guide will show you how to do it.
Opening your pool- An easy to follow guide
Opening your pool can be stressful. This Pool Start Up guide teaches everything from start-up chemicals, covers, and more for your start up.
