Hi - As some of you commented, I might have gotten too powerful a pump. ( I recently replaced a broken Hayward 1.0 with a 1.5 super-pump) The plus is that it is cleaning the pool faster through the Kreepy Kauly.
However, I noticed that every time I turn the pump off, a great deal of pressure was released, and so powerful that it pushes some water out from the pipe connector between the 2 valves (which usually don't leak when the pump is running). It looked like the pump was trying to spit out a large amount of water quickly.
And as a result of releasing most of the water - when I turn it back on again (without opening the pump cover or doing anything to release pressure), it would take 10 to 20 secs or so for enough water to pour back into the pump well to gain enough pressure again. It didn't happen to my old pump (1.0 hp). If I didn't touch anything, the pressure was retained and the pump would still be "primed" and ready to go.
Should I be worrying about the turn off? and the leaks on the connectors? Is there anything I can do to make the turn off less "violent"?
Thank you!
Thank you!
