The house I bought in 2014 had a brand new vinyl liner installed in the 24x24 circular in-ground play pool by the previous owner. Well, I'm starting to see why vinyl is so uncommon in the heat and intense UV of the desert. Very large (18-24") holes have begun to develop above the water line on the south-facing aspect of the pool. It looks as if the sunlight is just eating it away, and they are growing in size every day.
I've started calling around, but it seems that none of the pool construction/maintenance companies around here do vinyl, and none of them have been able to recommend somebody who does. What would you do if you were me?
