Very hot and sunny should i add extra chlorine
Kooky98
83
Ridgewood, NJ
Hi all, pool is at 85 degrees
Chlorine 5.5
Free .5
Ph 7.4
Will be gone all day. Should I bump up the Chlorine? Nobody will be in it for a few hours. Just don't want any issues due to heat and warm water.
I still consider myself new..
At 5.5, you are at the lower end of the target range. Feel free to bump it up to give yourself some extra buffer to ensure you stay well above the 4FC mark and enjoy your day away without having to worry about the pool.
Reactions: Kooky98
What is your CYA level?
I can increase later if needed.
Thanks!
