Not exactly correct. The Jandy AquaLink RS system can control both Jandy and Pentair (IntelliFlo specifically) pumps. I am not sure what a Pentair or Hayward system can control. however, if you ever go to a SWCG system then that mfg. of both SWCG and Automation needs to be the same.I was told that if pump is changed, controller can be changed to any brand. I am open to any solution for my goal to have a variable speed pump and wifi controller. Appreciate it.
How much are you willing to spend for an automation? It appears you were just trying to upgrade the older Z-4 unit with similar capabilities.
