I have an 26,000 gal 18x36 in-ground vinyl liner pool with a Pentair FNS PLS 60 DE filter, SWG and Hayward SP2605X7 3/4 HP Pump wired for 220 volts running on a timer. My system is running 1 1/2 pipe with 115’ of suction lines and 45’ of discharge lines, plus 8 90 degree elbows and 2 45’s. The 3/4 hp pump has done a great job, but is older and uses a lot of electricity. I would like to replace it with a variable speed 220 unit , and the Hayward Super Pump VS Variable Speed Pump 230V - W3SP2603VSP has been suggested as a replacement. Since my current 3/4 hp pump does a good job, I was concerned that the W3SP2603VSP with 1 1/2 hp may be oversized with too much pressure or flow. Has anyone replaced a SP2605X7 3/4 HP with a W3SP2603VSP 1 1/2 HP? Thanks for any input, I appreciate it.
