My 11 year old main 2HP Jandy Stealth pump failed. I swapped it with an identical booster pump that was powering my fountains that I never, ever use. I'm up and running, but I would like to take the opportunity to upgrade to a VS speed pump. I have an Aqualink automation system which supports VS pumps - it would appear physical installation only differs in that I have to run a separate communications wire from the pump to the Aqualink panel so that I can access the VS functionality. Software setup seems straightforward enough from my limited research though I'll need advice on how low I can go with the speeds based on whatever unit you folks recommend.
What pump do you folks recommend? In my Aqualink setup, I see "ePump, Intelliflo VS, Intelliflo VF, and VSP AC". I assume this will dictate what options I have. Thanks in advance for your suggestions!
Pool size: 16k, Salt in-ground pool/spa combo with cartridge filter
