Due to high running costs we want to replace our existing single speed pump for a variable speed pump. We are aware our existing pump is too powerful for our pool however at the time it was purchased we thought we had a 45,000 litre pool. Based on our pool specs in my signature can someone please suggest what would be the best VS pump option for us in Australia?
I was told by another pool owner with a VS pump that he needs to backwash prior to increasing the speed of his pump otherwise dirt gets blown back into his pool via the return jets. Is this normal?
Also, can someone please confirm if our current over-sized pump is the reason our sand filter has not been able to capture fine dust? I'm thinking the water is moving too fast through the filter and am hoping a VS pump running at lower RPM's will allow the filter to do a better job.
Advice would be welcome, thank you.
