- May 18, 2021
- 3
- Vinyl
- CircuPool Core-55
Hello,
My setup:
24,000 gallon in ground
Circupool core 55 swg
Raypak 300k BTU gas heater
Hayward Max Flo 2HP pump
Dolphin Active 30 robot vacuum
I am a new pool owner and would like to swap out the single speed pump with a variable speed. Ideally, I would be able to run it 24 hours a day at a low speed and then put the heater on a simple on/off timer I can control over wifi. The swg does not need a timer since it has flow detection.
How can I tell if a pump will fit without replumbing? I have 220v and 1.5” pipes connected to my current pump and was thinking about buying the Harris ProForce 1.5 HP Variable Speed pump.
I don’t have any waterfalls and I plan on using the robot for vacuuming, so I don’t think I need a lot of max power.
Thanks in advance.
My setup:
Thanks in advance.
