I have a Hayward AquaLogic system. It controls 2 valves and has 4 relays. I have two valve actuators connected, they're wired directly to the board. One relay is used for the pump and one for the lights, so I have two free aux relays. I'd like to automate turning on the vac (turn off main drain/turn on vac inlet). Is there a way to run two actuators off of an aux relay? Each valve would have to turn 90 degrees. Hayward valve. Thanks.
Update:
Apparently, my AQL-PS-4 can control 4 valves, so I'm good to go.
LL
Update:
LL
