Not sure if this is the right forum...please move if it's not.
My pool has 2 skimmers, and 2 main drains. The 2 main drains get combined into 1 pipe, so for all intents and purposes, it's really one. I can shut off the main drain, which leaves the 2 skimmers running. If I try to vacuum with this configuration, the suction makes vacuuming quite painful. I have to move super slow. Moving too fast, and it pushes the dirt around. It also doesn't have enough power to pull sand off the floor. (The vacuum head I use is shaped like a triangle, 12" on a side, with brushes around the edges and in the middle. The actual hole is probably 2-2.5 inches off the ground.)
The only other option to change the routing flow is to turn one of the skimmers off, but only way to do that means turning the main drains back on. In essence, 3 configs:
2 skimmers and main drain working
1 skimmer and main drain working
2 skimmers working
I tried plugging the hole of one skimmer using the device that is used to block the pipe in the winter (long blue floaty type thing), but it actually started to collapse that. I also noticed the basket at the pump was having more air in it, and filter pressure went down. For the 2 mins I did that, the vacuum worked much better, but I got nervous, so took out the device.
Is there something else I can try? Is a little bit of lower pressure ok, if I were to block the skimmer with something else? Should I find a new vacuum head that sits much closer to the floor?
Thanks
2 skimmers working
Thanks
