Noob question.
My pump on this new pool has a basket at pump.
Also the skimmer basket.
Do you leave skimmer basket in when putting vaccum plate in?
I use skimmer socks as well helps with pollen in my area.
Also this pump is pretty good and when I install vaccum piece in skimmer pulls air in.
I have to add or keep water level inch above vaccum 90 piece that goes in skimmer.
When I get air in I lose pump pressure.
To get air out I have to pull lid on pump basket and spill water every where.
Is it bad or hard on pump to get air in it for seconds?
Is there a valve I should have for this purge air out?
Where do I buy a plug for skimmer basket if I don't want water down to pump?
What I have been doing is hooking vaccum parts up while pump is running.
Filling hose and priming with return out of vaccum brush.
Keeping both under water.
Then hook up hose to piece in skimmer.
Sorry for the noob questions. I just don't want to mess up my new pool.
Thank you
Thank you
