Vacation suggestions
step
0
Aug 6, 2017
15
SAN ANTINIO, TEXAS
We will be gone for about 9 or 10 days and we would like any ideas as what to use. We currently use liguid chlorine daily as needed, but we are at a loss as to what to use while gone. The pump is on a time and runs twice daily. Thanks in advance:D
Do you have a cover?
What is your current CYA?
If you cannot cover, you can raise your FC to SLAM level based on CYA. Then get a floating puck dispenser and put a couple pucks in it. That will add some FC but also CYA which you will have to adjust to after you return.
The best is to get a neighbor or family member to add a set amount of LC each day or every other day. Adjust the amount to be added each time accordingly.
Take care.
