Good Morning,
A storm blew the cover and caps off of my (just installed last August & my first pool) 30' Round Above Ground Pool. We are in the process of getting the "green" out and balancing the chemicals. We have shocked the pool and put Fall Out to send the green to the bottom and are vacumming via the waste setting on the filter.
The TA is 80 ppm & pH is 8.2ppm..Pool Math Recommends adding 7.4 oz dry acid. Do you recommend any particular type. Also, Family Leisure gave me 5 lbs of Swim Clear Alkalinity Plus (Sodium Bicarbonate) will that lower the pH?
Should I be concerned with the Calcium Hardness? PM recommended is 0-650 & Ideal 50-550..mine shows 25ppm.
Thank you for your help and any suggestions welcome!!
