UWF for Polaris leaking?
delaneybob
195
Florida
CircuPool RJ-60 Plus
Hi,
I am speaking to the UWF (not the relief valve). My Polaris is slow and not the umpphh that it used to have noticed that the UWF appear to be leaking (I can see the water being disturbed on the surface).
When I put my finger on the relief valve connection to the UWF, the leak is pushing up against my finger so pretty sure the UWF is leaking
My Questions is a couple
1. I do not know if there is a restrictor ( I think I see the blue one form other end of pool) in there but does the UWF leak (again I am not talking about the piece with the Oring that is inserted into the wall)
2. I saw the you tube of leaving the Oring pressure relief vale piece in while attempting to remove- any other tips?
Hmmm it might be my tires way worse than I thought - I have white flaking- ordering new ones- still questioning the UWF though- thanks!
