Looking at getting a small hydrotherapy tub (150gal), and while I know that all hot tubs require SOME chlorine, I’ve heard that a UV system can reduce the amount of chlorine required by half (which is huge if you’re sitting in/inhaling this water for hours).
I would hope that with regular water changes (another reason we want a small 150gal tub), a UV system would be enough to keep the chlorine levels ultra low (1ppm? 2ppm?).
My question is - the model we’re looking at doesn’t offer a UV option, so how hard is it to retrofit an existing tub with something like this…
www.cleanwaterstore.com
I have zero plumbing experience, but follow directions well.
*or perhaps we could get away with just an ozone system (the factory will install one of those for an extra 100 bucks). Or maybe ozone + UV together? Willing to spend an extra 350 bucks if it means greatly reduced chlorine levels.
Thanks for any advice.
Ultraviolet Sterilizer Wonder Light Stainless Steel PC-2: 2 GPM 110v
Check out our low price on Ultraviolet Sterilizer Wonder Light Stainless Steel PC-2: 2 GPM 110v at Clean Water Store
