using Trichlor granules for CYA, how avoid staining vinyl pool?
Jameshowison
8
Austin, TX
My CYA is at 60ppm. I'm trying to get it to 80ppm as we have a happy new SWG (intex). It's an above ground pool and we don't have a skimmer.
I used a bottle of liquid gold to get it to 60ppm. I don't particularly want to buy another bottle (especially as quite a few threads suggest adding partial bottles is unreliable due the good stuff sticking to the side).
I would buy dry stabilizer and float a sock on a pool noodle, to avoid the dry stabilizer sitting on the vinyl. I'm not 100% I can keep it from bumping into the wall, but maybe tie it on the long pool pole across a corner, near enough the return?
But I have a giant bucket of trichlor granules left over from before finding TFP. I initially tried to use that to raise the CYA, but just sprinkling it in caused staining/bleaching on the bottom of the pool (a few wrinkles in the bottom cause it to collect).
Any reason I shouldn't just treat the trichlor like the dry stabilizer, stick it in a sock suspended in the path of the return?
I know that it will raise FC (even though it's old), but I can turn the SWG off for a few days no worries. "Effects of adding" also says Trichlor lowers pH (500 grams in my pool (~6k gallons) should raise CYA by 20, and lower pH by 1.1 (which is a lot, currently at a lovely 7.6, maybe 7.7). Dry stabilizer basically needs the same amount but lowers pH by a reasonable 0.4.
Thoughts?
Hah, tried this. Won’t do it again.
  • Horrible to load, chlorine smells terrible, risk dropping it everywhere.
  • Sock developed a large hole along a seam overnight. Socks were good before, so I think the chlorine ate them.
  • That meant granules on the bottom of the pool anyway. Total fail.
  • Hand stinks from squeezing sock.
  • I knew this would peak FC going in but that’s a downside too. Have t checked pH but I bet that sucks too.
So I ordered dry granules. Disposing of tricholor as I should have in the first place!
Are you sure they are trichlor and not dichlor? I’ve never seen trichlor granules, so interesting that they are a thing.
They may be very old - used to be very common in 1# bags at Walmart etc. before the great trichlor crisis.
Reactions: Bperry
