Using titration to determine pool volume?
SpongeBob
61
Austin, TX
CircuPool RJ-60
How feasible would it be to calculate pool water volume with FAS-DPD or some other type of tetration method. With the known chlorine level and known dosage and then known final level could Poolmath calculate approximate pool volume?
There is also a Chemical Way of Calculating Pool Volume using an alkalinity test kit, sodium bicarbonate or acid, and the formula.
Its best to use acid doses/ph/ ta measurements for this because the variable of accurate strength is removed since Muriatic acid doesn’t degrade like liquid chlorine.
Use the calculator at the bottom of the poolmath webpage here PoolMath
To get a starting point, also this one is very good
Then you fine tune it with the poolmath calculations, additions/testing.
