I use liquid chlorine each day for 31k gal. My CYA is 30. I’m consistently using 2.5ppm per day (water temp 84 and high temps between 85-90 each day), so I’m adding 3 quarts (sometimes a whole gallon— I think maybe the strength isn’t as high as it is supposed to be) of 10% each day. I have researched but keep seeing contradictory information. If I bump my CYA to 40, would it use less chlorine?? If there’s a way to not burn through these jugs so fast, I’m all for it!
