Just picked up a used Raypak p-r266a-en-c. Couldn’t pass up the price at $150. The burners look to be in great shape. Not too sure on the heat exchanger and tubes. I don’t currently have a heater but did run the gas line during my pool build. I know this heater is somewhat on the small side and if I was purchasing new I would have gone for the 400k unit. Some I plan on using this one for a few years or until it dies.
A few questions that I have is should I swap the inlet side or make it work with my current setup. The heater will have to go to the left of my pump/ filter. I could install the heater so the control panel faces towards the house. Again it’s not my forever setup. Or I run the plumbing behind the heater between the house and equipment. Make a 180 degree turn into the heater and then reverse back to the pool. I’ll attach a photo tomorrow of my setup.
Should I hook everything up and see if the exchanger leaks or perform some sort of pressure test with the water hose now?
I powered the unit up and control board works and the buttons seem to also. The current temperature was displayed. Would there be an immediate fault code if something was wrong?
Thanks for all the help
