Hi there
I had a question about starting up after pool renovation. We had our plaster poured on Monday, pool filled with water by mid-day Tuesday and we added muriatic acid and started the pump (I guess the pool plasterer mentioned that to my husband). We have been brushing the pool and continuing to add muriatic acid but 1) I don't see the dust clearing out much and 2) the filter doesn't seem to be gaining pressure as if it was.
So we did a bit more reading and it seems we should have either added acid OR started the pump but not both.
At this point, is it too late to turn off the pump and just do the acid or should we just keep running the pump and brushing multiple times a day. Does adding too much muriatic acid cause a problem running through the system?
Thanks for any help you can give.
