Basic question: 1) go with 6 breaker subpanel, 2) 6 breaker sub panel with intelliconnect, or 3) go with intellicenter.
My pool is 12k gal with an intelliflo i2, solar touch with solar heating array, in-line chlorine. No water features. In distant future, we may consider adding a spa. When I upgraded from an older fixed speed pump to the intelliflo, I left the old panel. I'm now considering transitioning to SWG; I'm looking at ic40 as it seems most appropriate for my pool. This will require a power center, and the power center will not have adequate supply from my current panel as all breakers are accounted for. So basically, I need to get rid of my old panel, and am looking at adding a 6 breaker subpanel in the very least for the power center. But it also seems like a good time to consider upgrading to smarter automation, either with intelliconnect or with intellicenter. Is there enough benefit with my present system + ic40 to upgrade to a smarter interface, or to take the even bigger step to intellicenter? I like the idea of smart control, but I also recognize my demands are pretty simple. Thanks for guidance
