We are going to replace our old fixed speed pump with the Pentair Intelliflow 2.6 VST. The pool has an attached in ground spa with a spillway into the pool. The pool has been running with a mechanical timer. When we use the spa the pool pump must be turned off, and we change the valves to circulate only in the spa. In the spa there is an air switch. With one press the pool pump turns on and the heater starts. One more press and the heater goes off while the pump continues to run. Another press and both pump and heater turns off.
I have looked at the IntelliCenter and IntelliCenter Lite but both seem to be unnecessarily complex for simple operation. I don't need to operate the pool and spa remotely but I suppose it is necessary when using the spa to control the heater on and off. The IntellliCenters are also very big and I don't really have space for one. Are there cheaper/ simpler control options available?
