We got a new 24ft pool installed in June. Been battling something since. We do have a massive tree that covers most of it and we've also had a very stormy summer. At this point, I can vacuum daily and the next day the floor is covered in a layer of "dust". It's very easy to brush and move towards the middle. The pool isn't cloudy, just has this layer I can't get rid of. Prior to coming here, I've floc'd, I've clarified, I've vacuumed to waste, I've backwashed a million times. My numbers have also been good according to the test strips. I then got a chemical test (not a good one) and noticed that those numbers never matched the test strip. Hence my looking around for help and coming here.
I'm ready to move over to bleach and actually have 12 gallons of liquid chlorine (10%) waiting for me at HD right now to begin the SLAM process. BUT, my Taylor 2006 kit won't be here until Wednesday. What can I do this weekend to start or at least not make things worse?
FWIW, both tests I have been doing show FC and TC to be high. Over 5ppm. I *think* the test strip shows an "ideal" PH and the chemical one shows it at 7.6. Strip shows TA to be around 80, but chemical test is more like 180. CYA seems to be high, near 100. The chemical test doesn't test for CYA, unless that's the same as acid demand?
SOOO moral of the story is they are both inaccurate. I'm aware of that. I have the good stuff coming, but I don't want my pool to get worse before it gets here. Should I just add a gallon a day until I can test for real?
