Unusual white stain? But isn't calcium..
Hi all,
I've just bashed washed my in-ground pool in preparation for my holiday's and noticed the following. If I brush/slash with water the marking disappears for a minute before returning. Anyone know what it is? I've never seen this before. Thanks!
PH: 7.7
TA: 100
FC: 7
CH: 375
CYA: 70
SALT: 5200
TEMP: 22c / 72f
Looks like efflorescence to me. One gets that when water behind plaster, grout, etc gets behind a wall. It then pushes the calcium /minerals forward.
A little diluted MA may help, but the only permanent cure is to keep the water from getting behind there.
Maddie :flower:
Before I had my tiles blasted for calcium, I noticed the build up was worse at the vertical grout lines. You can see it in the "before" pic on the bottom.
