- Jul 12, 2021
- 62
- Vinyl
- Hayward Aqua Rite (T-15)
Hello,
We just bought a house last year with a pool. We opened it this year, and with the help of this site, have learned much about maintaining it.
I have some questions about the equipment behavior that I was hoping you guys could answer.
Thank you in advance for your time.
as a rundown (also see diagram):
- 20,000gal in ground pool with 2 returns - 1 deep end surface, 1 shallow end surface at 90 degrees to each other. 1 skimmer opposite the deep end return. no main drain
- 1.5 inch piping
- 25-30ft from skimmer to pump
- 1.65HP variable speed Hayward, roughly 1.5 feet higher than skimmer intake
- no check valve between single intake pipe and pump
- 21 inch, 225lb sand filter with multi-port valve
- ancient heater
- 1 check valve from heater to pool returns
my questions:
- whenever I open the pump housing, the suction side tubing depressurizes and water level drops. I refill the housing with water before priming again. However, as soon as the pump is on, the level transiently drops back down to the bottom of the impeller intake, the pump is louder, and then 3-4 seconds later it starts filling with the suction water and primes itself fully. Is this normal? I don't like that the pump is starved of water, even for a few seconds. Should I install a check valve before the pump (on suction side) to maintain the water column while the pump housing is open?
When the pump housing opens, the filter also seems to depressurize. After I resume running the pump, and it refills with water, the filter has to purge itself of air too. It shoots a bunch of air out of the reutrns, then very small amounts of it for 5-10 minutes, and you can hear air in the filter body for some time, but gradually it gets rid of it all. Is this normal?
Whenever I rotate the multiport valve, that is, whenever I press the handle down, the filter depressurizes itself as well. This also leads to some air bubbles going back into the pump. Is this normal?
Again, I am trying to avoid situations where any air is introduced into the pump and causes it to run (even if partially) dry.
Final question - does anyone have advice about improving flow in the right lower corner of the pool (closest to the equipment pad) where there is no return jet. It is the main dead area of the pool. I was considering one of those rotating jets with gears in them.
Thank you very much!!
- 1.5 inch piping
- ancient heater
my questions:
