- Jun 14, 2012
- 2,668
- Vinyl
- CircuPool Edge-40
If you are not using Trichlor or Dichlor then they might want to get you to the 100 CYA level right away to promote a model of chlorination that uses weekly additions of chlorine - but this model doesn't work. Many people following that model end up here after frustration and $$$$ and time wasted.
If you were planning to use Trichlor pucks and Dichlor shock - then they are foolish indeed since your CYA would skyrocket over time and you would eventually have to drain and refill at least partially to get things under control since CYA doesn't go away under normal conditions.
