- Jul 29, 2017
- 215
- Plaster
- Pentair Intellichlor IC-40
I have a problem with my upgrade plan.
I wanted to use all Pentair equipment to include the IntelliCenter and IC60. Unfortunately that combo doesn’t come as a package from Pentair. The company I am working with won’t buy it from Polytec. They want to use the IntelliCenter with IC40, add the IC60, and then charge me a 50% restocking fee to take back the IC40.
I won’t do that which leaves me with a few less than perfect options. I can buy the panel with the cell I want and install it myself but I will only get a 60 day warranty. I need to decide if the cost saving makes that viable. I could also change plans completely and eliminate the IntelliCenter.
Another option is to go with the IC40 system and upgrade to the IC60 when it needs to be replaced. One advantage to that is the 3 year bundle warranty on everything. With my pool holding 37,000 gallons I guess I will need to run the Intelliflo pump 24 hours to generate enough chlorine.
In that scenario can I add some liquid chlorine occasionally if needed? Are there any other potential problems with cutting it close on the cell size?
