Hello. I had a heat pump installed. My system runs off of one pump. In normal operation, the spillover from the spa is always running. I can't for the life of me figure out how to turn off the waterfall so that I can independently heat the spa.
My issues:
1. I can obviously turn off the spa return and stop the waterfall. However, I cannot heat the spa then.
2. I can turn off the pool return and the aeration increases and the spillover increases.
3. If I turn the spa lever on the right, it's the bubbles. The waterfall continues and aeration pressure increases in the spa but the pool aeration seems to stop.
4. If I turn the spa lever on the left, I believe its the spa main drain. The waterfall stops of course the water level continues to go down. I haven't just let it sit but I'm assuming the spa will drain into the pool?
This all leads me to believe, unfortunately, that I can only heat my spa with the spillover running. Is that correct? Why would someone build something that way? What options do I have to fix it?
My issues:
