- Nov 7, 2018
- 1,049
- Plaster
- CircuPool RJ-60 Plus
I have a TriStar two speed pump that is currently wired to run in high speed only. I am not sure why the original owner did this, but that's how it is wired. Before I go tearing stuff up to re-wire the pump to the panel, I want to make sure the low speed side pump actually works. So, are there any issue with moving the L1 line (high speed) to the A terminal (low speed)? The only thing I am really unsure of is the pump starting in low speed (I have some confusion on windings/start-up/etc.) If this works, then I would really only need the low speed side of the motor, so I would probably leave it as is. Thoughts/opinions?
