- Aug 27, 2012
- 29
Greetings all,
I have a fiberglass pool that has a leak which my wife and I are pretty sure is located at the front edge of the skimmer. The pool was put in in 2006, and the sealant in that area was peeling off, and the gasket between the faceplate and the pool is definitely degraded, leaving sooty deposits in that area of the skimmer and just crumbling apart. So we got a new faceplate (the old one was discolored) and a new gasket, and we took off the old faceplate today (fortunately no unpleasant surprises).
When we got the faceplate off, we learned a little more about how the installer may have applied sealant the first time:
(1) When I took out the screws, it was obvious that there was some residual extruded sealant that had been squeezed out of the screw holes when the screws originally went in. To us, that suggests the installer squeezed a little sealant into the screw holes, and then screwed into the wet sealant, thereby making a better seal than screws alone.
(2) The original gasket was stuck to the side of the pool when we got the faceplate off, which didn't surprise us, but as we scraped it off in bits, it looked like there was a thin, even white layer of something...presumably sealant...on the back of the gasket where it attached to the side of the pool. Some of the crumbling gasket was also stuck to the back of the faceplate, but there was not a thin layer of sealant between the gasket and the back of the face plate.
So, what I am wondering is this: When we put the new gasket and faceplate on, should we replicate what we THINK the installer did the first time with respect to sealant? That is, squirt some in the screw holes before replacing screws, and putting a thin layer of sealant on the side of the gasket making contact with the pool side?
If not, thanks so much for letting us know how and where we should apply the sealer (Boss 801) as we put the new gasket and faceplate back on!
Otherchuck
Otherchuck
