So I have been slamming for 6 days now, and although all the aalgea is gone, and I can see the bottom of my liner in shallow end, the pool is still cloudy.
My current numbers.
FC 14
CYA 30
CC 0
I added 3 cups of DE to my sand filter last night and watched it closely. 3 cups was enough to raise the PSI by 1. After added, it raised my PSI like 10-15 points every 1 to 1.5 hours.
is this normal? I just backwashed and added 3 cups of DE again. Once again, had to backwash agfter 1 to 1.5 hours. I did this about 3 times.
Should I leave the DE in there longer?
This morning the water did look a bit clearer, but I did not want to leave the DE in overnight because I guess someone bad can happen if I let the PSI keep rising right?
Am I doing this DE thing right is my question?
Should I just add 2 cups and let the PSI rise at a lower rate? Or will it not work then?
My current numbers.
FC 14
CYA 30
CC 0
