Hey all,
I've been following most of the closing threads, including Catanzaro's excellent thread (should be stickied, perhaps?), however, I am still not completely clear on the concept of blowing out the main drain line.
So the returns make sense - you lower the water level below the returns, and blow all the water out of the piping and plug the ends - what's left *should* just be air all winter. However, the main drain remains completely submerged. Surely even if you can build enough air pressure to blow it out and plug it, the water will just leak back in, because there's no way to plug the drain at the bottom. Am I missing something?
