Like the title says...
Have a negative edge glass tile spa that was running perfect. Flowing over on all 4 corners seamlessly.
I have hard water and noticed some white chalky hazing on the sides of the spa when turned off and it dried.
so I used a acid/water ratio to clean the tile. Then I applied the ocean care sealer protectant stuff.
go to start the pump back up and now the spa is not flowing over seemlessly anymore. Two corners and multiple other areas on straight lines of the spa are not spilling over. It’s like it’s repelling the water in those spots forcing the water to flow in areas with the least resistance.
Its got to have some kind of ceramic or silicon agent in it.
Nevertheless, been trying to reach out to the company to find out what I can use to remove this stuff. Or at least what ingredients are in it so I can use my own judgement on removing it.
should I use a stronger ratio of acid to get it off? Any suggestions would be great. I’m literally ****** at myself as I tried to eliminate an issue and created a much bigger one for myself.
thanks so much.
thanks so much.
